Bought a 04 Silverado 1100 and will have it stored in San Antonio Tx for 2 months out of every 3, sometimes it may stretch to 3 month stored and then I'll get to ride it. It's covered by a moto cover.
I've removed the battery and put it on a battery tender.
I've put Stabil in the gas tank and run it for about 5 minutes prior to shutting it down.
When I get back to it anyone have any recommendations as to start up? There may be no problems. I will change the oil this time shortly after I get there and run it awhile but I need to run it to get the oil warm anyway.
Should I drain the oil prior to shutting it down each time I leave it?
Any other procedures you'd suggest on shut down?
Any other procedures you'd suggest on start up?
I'd make sure your tank is topped off. You're already planning on adding staybil, and putting the battery on a tender. I wouldn't drain the oil, depending on the time frame, I'd might change it prior to riding it again. If its only been a couple of months, the oil should be fine.
