08 stratoliner. Replaced tps and set to samespot as last one idle and throttle sermed fine... once i turned of key and restarted it will start but it spudders and dies. Checked fuel its getting fuel and spark plugs brand new and working. Not sure where to go from here.
What was the ohm reading? They must be set with a meter, no two sensors are exactly the same. That's why they have slotted screw slots.
108373
If you need service manual, here's the link:
Reactions: ArizonaWarrior
Discussion Starter · #5 ·
I am a novice with all this and im not sure how to test this i read the manual but i dont know where to put the leads without damaging the sensor. sorry not the best answer but happy to learn
anybody know the tps voltage at wot ?
