So I recently had new Vance and Hines Radius 2 into 2 put in. Has anybody had ant issues with pipe coming out to far and basically sitting on there leg. Was it put on wrong or do I need longer pegs. Its the top exhaust were it curves out.
i have the same pipes on my 950. i assume you're talking about how far the rear pipe sticks out at the first bend next to your calf. it's just something to get used to. since mine are coated in black ceramic, i don't have an issue with getting burned or melting anything to it. if you really don't like your setup after a while, look into getting it coated. cost me $200 back in 2011 and still looks great, plus helps the engine run cooler.
