1 - 11 of 11 Posts
So I was on my way home from work tonight when I noticed that one of my running lights wasn't on. Of course I pulled over to find out what was going on, assuming that the light bulb burnt out, only to find the the left running light hanging off to the side (first pic)....It had vibrated off of the mount lol. Luckily I keep a couple things in my saddle bags for emergency repairs, one of which is electrical tape. I taped the top and bottom lights together and drove home. Honestly, I was pretty surprised at how well it worked; after 10 more miles of driving I got home and everything was still securely in place. I reattached the light housing and tightened the nut that holds it in place. After fixing that problem I realize that the other running light was loose. So I tightened that one down too...well I ended up shorting out the circuit because I had the live wire just barely exposed and it grounded out...oops. So I had to take everything apart again electrical tape the exposed portion of wire and put everything back together again. Now I have to wait til morning to go get a replacement fuse, but everything worked out ok. The moral of the story: Check your running lights every so often :D
So, what are some things that you guys keep on your bike for emergency repairs (other than tools)?
I keep electrical tape, rags and zip ties.
A little blue Loctite maybe?? Glad you had the necessary quick fix with you. I always carry electrical tape and bungee cords in the bags. So far lucky and haven't needed them, but you all know Murphy's Law is quick to assert itself :D:D
Thread reminds me to redo the wife's license plate mount. She didn't know what the 'springs' where for on the reflective bolts when she put her plate on.
Vibration is a cruel mistress. I 2nd some blue loctite on those lights.
I need to think about emergency fix items like tape and zipties, and get a c02 tire kit on order.
I've been lucky, needa get a kit together before it wares out.
Can't say enough about duct tape. also matches or bic lighter. I keep a small 1x4 block of wood, for when i have to park on not so solid ground.
plus what you guys already mentioned, and some rain suits.
Ya I keep bungee cords on my bike too. I only bring my rain gear if I'm going on a long ride or if there is above a 20% chance of rain in my area. I really should invest in a CO2 tire kit though, that would have come in handy a month or so back when I got a flat on the freeway =( I also forgot to mention that I keep a knife on the bike too in case I have to deal with wires.
I keep a microfiber towel and a can of Plexus so when I stop I can clean the windscreen. I probably should at least put the toolkit back on top on the battery...or at least keep it in one of the bags along with some tape, dikes, flashlight, and some replacement bulbs. Maybe even a basic tire kit. I mean, the bags aren't doing anything else. Why not? It would only add a couple pounds.
After reading this thread I have to admit I have a tool bag but none of the other items mentioned. I think the best ones to have are the zip ties, electrical tape, Wire cutters (which can double as stripper, crimper) Some butt splices, A length of extra shielded wire would be handy. (if not need for electrical repair it could be used as a wire tie.)
A fuse puller, Extra fuses, Rag, small spray bottle for the windshield for sure.
We have small plastic storage boxes, one for phone cords & cords for the Bluetooth on the helmets. Another with tools ( pliers, side cuts, Allen wrenches, some sockets, screwdrivers, open end wrenches.) A small first aid kit. A battery powered inflator/ tire gauge. A large "survival" type knife. A couple small LED flashlights. 2 or 3 kick stand plates ( in case someone needs one). And when I remember to charge it, my Micro Start battery pack for jump start if needed. Need to remember to add electrical tape and wire ties. All that, and still enough room for a jacket or two! But not much else, lol
Ahhhhh, I have the perfect knife.... Glad you reminded me of it.
:D
I will have to admit that other than the stock tool bag provided with the bike I don't carry a single item like tools, emergency gear, etc. Not that there is anything wrong with it I just choose not to. I don't carry tools in my car or truck either. Never have and probably never will. As far as the bike, I hardly ever get more than a couple hrs. from home. If I breakdown, I will call the wife or a friend to grab my trailer and come get me. Other times that I am farther from home I have always been with others. Honestly breaking down is not something I worry about. Worst case I call a wrecker and let him haul me home. To each his own I guess! :cool:
We have roadside and towing with every vehicle and bike, absolutely worth the extra $8/mo.
TCLOCS will save 90% of problems. Can't prevent punctures though, which was a heavy factor in buying a newer bike with tubeless. Though now the wife's new bike has tubes. I'll do a lot on the side of the road, but I'm not removing a rear tire to replace a tube on the side of a road. Its getting towed. I might on a front tire if conditions are perfect and I'm feeling frisky, but I'd be lying to myself if I said I would after hours of riding.
1 - 11 of 11 Posts
