I was wondering if anyone has installed any aftermarket exhaust on a 2018 eluder/venture. I have a blacked out 2018 Star Eluder, and installed the Tab aftermarket slip on exhaust. Sounds great, not to loud and the right amount of rumble. Just wondering if I should get a powercommander or some type of tuner. It seems to run great with the exhaust but I worry about it running lean or extra hot. I only have the stock air intake on it. And the Tab exhaust is just slip on mufflers so I didn't change the entire exhaust system.
Any input would be appreciated!!!
Thanks!
I should think you would be ok as long as you didn't change air intake. But i am no eluder expert. I would think you may get a little more performance out of it if you did get controller.
Much like Deeks, I’m no expert, however if you only changed out the mufflers and not the entire system, you should be ok.
And he’s correct about the air intake system. You won’t see significant changes in performance with mufflers only, just a better sound.
