Hey there everyone
I started to install all the parts I had ordered and received over the last few months. I was able to get fender trim, caliper covers, driving light eye brows handle bars, mirrors and grips all changed. Still lots more to do but it's a start lol. After changing the bars and grips I ha e a throttle that does not pop back when you twist it . Anyone have an opinion on what is up, pretty sure cables are all ok not pinched or crimped or anything . I did not install apes or anything like that requiring longer cables . Thanks folks
If you replaced a new throttle tube with grips the issue might be there. Try loosening the throttle housing slightly. If the throttle turns freely and returns fully, the issue can be easily fixed. Some times the new throttle tube where the cables attach will have some extra plastic left over from casting. You can take a small file and knock off those spots. It's actually a pretty common issue.
94501
