1 - 2 of 2 Posts
I got my front Shinko 230 mounted and installed on the bike. Everything seems ok, and it balanced out nice, but if I spin the tire on the axle, it seems to shift from side to side a bit. I spun it and was able to measure about a millimeter or two of side to side movement where the tread meets the sidewall. Is this normal? Do I need to re-seat the bead? I looked at the bead alignment with flash light and it seems to be lined up all around the tire on both sides. I wanted to check before I installed the brake callipers in case I need to re-install the tire.
Discussion Starter #2
An update in case anybody happens to stop by the thread.
I re-mounted the tire, making sure I used plenty of soapy water just in case the bead didn't seat properly, and it did the same thing. So I put it all together and took it for a ride. I did not notice anything like wobble or shake, and I leaned over to watch the tire at different speeds, couldn't see the movement while going down the road. I will ride it for a bit and see what happens..........
1 - 2 of 2 Posts
