Does anyone have experience with LEDs for tail / brake light use on the Royal stars?
The royalstar, if I am not mistaken, has the same shape tail light of a vstar 1100 classic. On mine I have put an integrated led tail light. This handles running and brake light, as well as turn signals. I left on the stock turns as well. I also have a run turn brake kit as well that cause my brake light to flash. Very bright and attention getting.
The only thing I have experienced with led lights is that the amperage on the blinkers may not be a heavy enough load to make the flasher work. If this happens thy make a ballast resistor to emulate the standard bulb. Hope this helps, and good luck!
