I posted this question in the intro forum yesterday, but want to make sure it gets visibility in the right place. I have an 04 Road Star that is DOA. Transmission started jumping out of gear on hard launches. Then eventually degraded to jumping out of gear in 1st, 2nd and 3rd. Anybody else know of this issue. Does engine have to be removed to fix? How hard is engine removal? Dealer wants $1200-1500. Thanks
I was hoping someone with that bike would jump in. Generally, transmission problems involve removing the engine and transmission from the bike and splitting the cases for inspection. It will involve a lot of labor hours, and until that is done you will have no idea of the number and cost of parts. You can be assured that the dealership will not have the parts in stock, so you might be in for a long wait on back orders. Hope you have a backup bike for the rest of the summer.
Same here. I was thinking possibly worn shift fork (or, rather, Google was) but have no experience with the repair.
If the original poster is incredibly lucky, the problem might be in the external shift indexing parts, which should be accessible from the outside.
Since there are said to be at least three gears involved, I'd say there are at least two shift forks or their dog clutches involved. If the dog clutches are worn, the slots in the gears into which they mesh are probably worn too. I sure hope the fun of all those hard launches offset the expense of the repairs.
Thanks for input
Thanks for the feedback. I'll check manual for external shifter access. I do believe it's the indexing system. When I say hard launches, I don't abuse my bikes but I do like to get moving quickly - no smoke. Luckily I have a backup or two.
