I bought this 2009 V-Star 950 from a coworker. One day, it just stopped moving on him. Engine still ran, but he figured it was a clutch issue (nope). Obviously, shop time is expensive, and just to get it diagnosed would have cost him more than he wanted to shell out. I was looking for a project and was pretty certain I knew exactly what killed off this bike. Made an offer and got it out of his way and into mine...
Let's pop off the pulley cover and see what stories it has to tell...yep...horror stories.
Red dust of death killed off this transmission at around 30,000 miles. Belt was tensioned waaay too tight when I got it, the 950s should be set to the low end of the spec and maybe less...just enough to keep it on the pulleys. When it is tight, it likes to ride on the outside of the output pulley and that lateral load is what sets off the destruction.
Some say the engine is out of alignment in the frame and it is impossible to get the belt to track straight. There is no room for shims or movement in the engine mounts, so the easiest way to compensate is to run the belt a bit loose. Yuck.
Up on the lift so I can pull the wheel, belt and pulley.
With the wheel and belt on, the front pulley and nut were tight, I couldn't get either to wiggle...As soon as the tension was off of the belt, I didnt even need a breaker bar. The pulley also moved all over the place behind the nut....Scary.
All that red dust is what is left of the splines....a fine red rusty dust.
Time to shop for parts and figure out how to pull this engine...(I'm actually about ready to put it all back together, I just thought I'd start posting up what I have done up to this point...stay tuned, more incoming.)
