Tri-Star XP 1016 Turn Signal to Brake and Running Light Conversion $41.00 Shipped
Signal Dynamics Corporation Tri-Star XP Turn Signal to Brake Conversion with Running Lights P/N 1016
41.00 Shipped
Brand new. Never installed. Brushed aluminum in color.
Converts your rear turn signal lights to function as additional brake lights
Waterproof and heat resistant
Sends partial intensity power to your turn signals to act as additional running lights
When the brakes are applied, the turn signal lights illuminate giving your more rear visibility when you are stopped
If a turn signal is applied, it has priority over the brake light function on the side that is selected. If the turn signal is canceled and the brakes are still applied, the brake light functions of the turn signal lights illuminate steady on
The included Dual-Load Equalizer is designed to fix the problem when you have changed your stock turn signals to L.E.D.s and they flash quickly or not at all
