That's pretty neat. I'll bet it took some engineering on that one. :)
Actually, it wouldn't be that hard to make... first you would empty out the entire casing, then run a couple of plastic lines through the empty shell to the carbs. The hard part would be fabricating a way to mount the taps (all the cooling happens under the counter) and even that would be relatively easy if you can weld. After that all you have to do is bolt it onto the counter, hook up your lines to the keg and away you go! :D
Bet those straight pipes are kinda loud indoors. :cool:
