I'm replacing my clutch friction plates and steel plates with the Barnett kit: Yamaha Clutch Plate Kit- Kevlar
Part# 306-90-10072
I'm at the point where I start removing the old plates. Well, the old friction plates have a single notch on one tab and a double notch on another tab opposite of the single notch. The new friction plates do not have these notches. I noticed that all these notches are aligned. The only concern I have is the new friction plates do not have these notches. Before I install them I'm curious if this will cause an issue with the new plates not having the notches.
Any help will be greatly appreciated!
i think those plates are supposed to be used with a barnett clutch basket because the yamaha basket has indicator marks for the double notched tabs, when you removed your plates were the friction pads one behind the other or were they staggered. that's what i'd be looking for when installing the barnett discs, if you don't get it right you can end up with a dragging clutch
My bike's basket didn't even have the two dimples on it to mark where the double notch should be. But I installed the new fiction plates and steels rings as well as the Barnett spring conversion, put it all back together gave her brand new oil and the rest is history. She rides like a dream again. I forgot what it was like to crack her throttle and actually have the bike accelerate, smiles all day!
