I just put together some more "SSD" (Shutoff Solenoid Delete) kits for 2006 - up V Star 1100's. If you've done the "POD" modifications and gone to aftermarket pipes/mufflers, you know those solenoids in the float bowls aren't doing much of anything except hanging there with an ugly wire coming out. The problem with removal is that the check engine light will flash a trouble code (57 and 58) if it can not find them hooked up in the system.
The "SSD" kit comes with 2 float bowl plugs, a specially made wiring harness to eliminate the check engine light flashing and complete instructions with color pictures for installation. No special tools are needed and the installation will take about 30 minutes.
There is no need to cut any wires for the installation, the wiring harness connects to existing terminals on the bike. I have thoroughly tested these and they have performed flawlessly.
Max Air sells their "kit" for $45 not including shipping which runs about $6.35. I am just asking for enough to cover my time and materials used in assembly. The "SSD" kit runs only $25 shipped to your door (CON USA Only).
Clean up the engine area of your bike without breaking the bank! Hopefully these will make things a lot less cluttered than they did before.
Yes I do take PayPal. Price would be $30 total to Oz.
I sent you a PM....
