1 - 13 of 13 Posts
Hello,
My 2006 V Star 1100 Silverado won't start. It has about 15800+ miles on it.
I rode it last Friday from work (in rain). It kept sitting on whole weekend and on Monday it won't start. I changed the Spark plugs (since they have not been changed since I bought it at 7000 miles). I also ensured Battery is fully charged.I can hear the starter turning, making a whine, but no ignition. The starter is turning i think, but what could it be?
I have been reading about this problem, and I have been reading a lot of cases of Starter Clutch going bad for this model, and at about this mileage.
I have an appointment with the motorcycle mechanic for May 20 (its a bummer, that I do not have enough mechanics here, Iowa!), but is there anything I can do to cover the basics, at least?
I am no expert in working on a motorcycle, but had changed Oil and Filter (which is a pain for this model), spark plugs, gear oil etc.
Another question: If it is indeed the Starter Clutch issue, should I buy the OEM @$400, or go with the after market ones from Ebay etc (@ $100)? Any suggestions/recommendation for After Market?
What is the life of these Starter Clutches usually?
Thanks in advance!
We need more information in order to help you more. As tre607 asked, is the motor turning over or just the starter spinning freely?
Thanks for the quick replies. I am not sure how to tell the difference between Starter and Starter Clutch (Apologies for not being knowledgeable here). I was thinking to wait until the mechanic investigates it, which as I said is May 20.
But you guys give me hope!
What I will do is record a Video of how my motorcycle behave and post it here.
It will be great if you can tell by the sound of it what's going on, or what should I check first. I will upload a video by tonight.
Thanks!
I just googled bad starter clutch and it sounds a lot like what you've got going on.. :(
Maybe the video above will help?
GL!
eGo
Thanks for the links and recommendations
Do you think i should get the OEM ones or after market? What is usually life of these?
I know i have been (unknowningly) using throttle a lot when starting up a cold engine, which may haveto add to this condition.
Discussion Starter #12
Thanks for the reply, Corsair.
Do anyone know life on these? I am trying to weigh my options of replacing with an OEM vs After Market.
Also, Is anyone aware of how much the mechanic would charge to do the replacement?
I have a few sources for the OEM Replacement kit
1. AMAZON: $365
http://amzn.com/B005IGNZC6
2. Ebay: $249.99
http://www.ebay.com/itm/VStar-V-Star-XVS-1100-XVS1100-Update-One-Way-Starter-Clutch-Damper-Kits-99-09-/321661598035?_trksid=p2141725.m3641.l6368
(The seller claims its NEW OEM Product.)
Let me know!
I just watched a video on how to replace a starter clutch and there's a lot of work involved. So I would go with OEM replacement parts just because of the amount of work involved. I personally buy everything from Amazon without any problems. I haven't bought anything within the last 10 years from eBay but when I did buy from eBay I didn't have any problems with any of the sellers.
1 - 13 of 13 Posts
