Replacing the front brake pads are on my list of things to be done to the bike. I have replaced them before on multiple bikes and am quite familiar with the process, however have never dealt with a "Shim" before.
On the parts list (Partzilla parts exploded view) it shows a "Shim" on the inboard side of each caliper behind the brake pad, only the inboard side (item 12 and 22 shown).
I have watch at least two YouTube videos on front brake pad replacement on the V-Star 1300 and nowhere is mentioned or shown a "shim". I contacted one of the authors of the videos and he did not seem to know anything about them. He shows the front caliper removal and the pads removed and replaced but again, no "shim" present or shown or discussed. The same is true of the other Video, except my contact to him.
Here is the question: What is the "Shim" for and is always required or is it an "as needed item" in certain circumstances? I suspect that when i pull the old pads off there will be no shim as this will be the second time the pads were replaced.
What exactly is the deal with the "Shims" in this case?? I was hoping someone knows. Thanks
