V Star 650 Carburetor issue?
16915 Views 43 Replies 13 Participants Last post by  Pancake81
Hello, everyone. I hope everyone is having a good day/night. I just recently bought a V star 650 Classic (01) for $1,500. The person who sold it to me said he was selling it for so cheap because he said he messed up the carburetor trying to do a DIY job. Something to do with either the needle inside the carb. So he says. When I start the bike cold, and turn the choke on, it idles good and everything. But when I open the throttle it dies. On my rebel 250 when I did a cold start on her she would let me open the throttle to get the revs up. But that's not even the main issue. The main issue is on 1st gear, when I wanna take off it feels like its about to die, so I open the throttle more and it does the job. I didn't think it required so much throttle to be open. The other issue arose when I was on the highway. I noticed that I went up through all the gears on the 650 and it didn't want surpass 60 mph. Which was pretty bizarre to me. Because my 250 would go 85mph and reach its max speed. It honestly felt like it wanted to go more but it couldn't. The revs weren't even high. In my introduction I gave an example that went something like this "it felt like it was the weight of a 650 but the power of a 250" maybe even less than the 250 tbh. I only say that because it didn't want to go pass 60mph. I just wanted to know if you guys would recommend switching both carburetors out with new ones? Would that fix the problem im having? Thank you so much for taking the time to read this thread. I hope everyone has a good day/night. Any help would be grateful thanks.
92161
See less See more
Reactions: 2
1 - 20 of 44 Posts
If you're sure it's a carb issue (which it sounds like it is) you'd be better off doing a cleaning and rebuild. I'm not a carb expert but there are some members here who know them well and can talk you through it if you have some mechanical abilities. If that's not something you're comfortable doing it would probably be cheaper to pay a shop to do it than to just replace the carbs.
Reactions: 1
if you go to bikebandit.com and put in the year make and model for your bike
then you can follow the OEM parts tree down and find out how much a new carb will cost for your bike
make sure you are sitting down - 1 new carb will cost more than you paid for the bike - for the price of 2 new carbs you could get a really nice ready to ride low miles 1100, 1300, Road Star, Royal Star....
attempting to fix the carb yourself is the lowest cost way, the kit with the replacement jets and seals (o rings) is not expensive, but it will take at least 6 hours of your time to get the carbs off the bike, go over them and adjust them, put them back on the bike, and then do some fine tuning.
that is assuming the carbs have not been ruined by the previous owner
another option is to find a used carb for the one you think is bad, either by shopping around at local bike repair shops to see if someone has one, or looking on ebay or craigslist for someone parting out a wrecked bike
there is still some risk of getting a used carb that needs to be cleaned, but if the history of the bike is known and someone was riding it regularily and something happened to the bike, you have good odds of getting a good used carb
From your other posts it sounds like the bike is running on one piston - it should be easy to see which exhaust pipe quickly gets hot when you start it, and which one is just getting warm. The warm one has the bad carb.
You can down load the yamaha factory service manual free in pdf format - easy to find with google. Read thru the section on removing the bad carb from the bike, see if you think you would be comfortable with that level of work. No special tools are required, you will need a torque wrench to put the bike back together properly without stripping out the bolts that screw into aluminum
Go from there - let us know how you want to proceed. There are people here who can walk you thru the carb rebuild.
See less See more
Reactions: 2
You will have one disadvantage rebuilding the carb yourself. The previous owner had it apart and screwed it up.
Normally if the carb has never been touched since the bike was new, you can take it apart screw by screw, take photos of everything, make notes of where every part goes, and then clean it as you go and put it back together with the new parts from the carb kit
but the previous owner was in there, and did something wrong - so there may be parts or washers or spacers... in the wrong place, or missing
in other words, if you put it back together the way it was with new parts, it might still be put together wrong
that is where taking the carb to a shop might be better - someone who has rebuilt them before will know where all the parts go, and will know if something on the carb body is damaged.
you can figure it out by yourself from looking at the exploded carb drawings in the manual and at bikebandit.com, but it will be a tedious process
Reactions: 1
noticed in your other thread you are having trouble getting the bike to start
if its only running on one cylinder that is understandable
the normal sequence is to pull the choke all the way out
turn the key to run and wait till the fuel pump stops running
crank the starter with NO throttle twist
the bike should start within 3 to 5 seconds (normally)
as soon as the bike fires you can let go of the starter and then give it just a bit of throttle
and you should be able to push the choke in half way
after about 3 minutes of idleing or riding you should be able to push the choke in all the way
if the bike is running on one cylinder its going to be difficult to start
but you just need to get it running again enough to see which carb is bad
dont ride the bike anymore like it is - if one cylinder is not firing that piston could be getting washed down with un-burnt fuel
or it might not be getting any fuel at all - you can only tell by pulling the spark plug out, see if its soaked with gasoline
See less See more
Reactions: 1
One more think
this may not apply to you, if the previous owner damaged the carb
but if a bike is running on one cylinder, its also possible the float bowl is stuck and the carb is flooding out the cylinder - too much fuel for it to fire
normally gas would come out the carb overflow tube, down on the right side of the top of the engine case, and drip on the ground. If its doing that while you are riding you might not notice, but you should be smelling gasoline.
If the float is stuck and flooding the carb it may have flooded gas into the crankcase, seriously diluting the oil. That is not good - dilution with gasoline will damage the bearings and destroy the engine.
If there is evidence the carb was overflowing, change the oil before you run the bike again
usually you can take the oil filler cap off and see if the crankcase smells like gasoline
again this may not apply to you, but it would for future thread readers with a bike running on one cylinder
This is another reason to not ride your bike if its not running right, esp running on one cylinder.
See less See more
Reactions: 1
You can down load the yamaha factory service manual free in pdf format - easy to find with google. Read thru the section on removing the bad carb from the bike, see if you think you would be comfortable with that level of work. No special tools are required, you will need a tourrque wrench to put the bike back together properly without stripping out the bolts that screw into aluminum
Thank you so much for the wise help. Ive been on bike bandit a lot very good site ill be sure to check out the Yama section. Yes, it does feel like Im running on 1 cylinder. The good thing is that it drives. I don't mind taking the time out to rebuilding a carb. I have something fun to do now! Hahaha. How does one tune the bike? Is it through the valves? Im fairly new to wrench work but not afraid to learn.
For
One more think
fortunately this does not apply to me, but I would like to know more about what you are talking about.
when you clean a carb there are two things that will need to be tuned.. maybe three
you will take the Pilot Main screws (PM screws or PMS) out and put them back in. The manual tells you to gently screw them in until they seat, and then back them out a specific number of turns (2... 2 1/2... its in the manual)
that is the starting point - you will ride the bike and see how it runs, and then if necessary nudge them in or out to get it perfect
also if you take the carbs apart you will probably need to re-synch them - this gets them both equally open when the engine is idling, so that one piston is not producing more power than the other
the 3rd thing - you might need to adjust the idle speed
if you have the bike torn down to where the carbs are off, that is also a good time to check the valve clearance and adjust them if needed - you can only get to the tappets when the carbs are off the bike (which is a 2 hour process to get the carbs off and put them back on)
so while you are in there, its only about 20 minutes more to check them. If you do get new o rings for the tappet covers.
See less See more
Reactions: 2
My sequence is this please correct me if im doing something wrong. 1) turn key on 2) cut off switch on 3) push to start 4) open choke. After that I try and opening the throttle with the choke on and it turns off. When I try and take off on a cold start (after turning the choke off and letting it warm) the bike seems to stutter almost seem to die not sure if its taking long time to warm up. Is there anywhere I can post a video to show exactly what im talking about?
the stuck float
in the carb there is a float that opens a valve that allows gasoline to fill the carb float bowl.
when the bowl is full the float pushes the valve shut
if the float or valve gets sticky or gummy, it might stick open or closed
if its stuck closed that carb will get zero fuel
if its stuck open that carb will overflow, with fuel going out the overflow tube and into the piston
Reactions: 2
Perfect, thank you so much for the advice. Im gonna start ordering the parts and be posting them on here to make sure im grabbing the right kits if that's okay. I hope I can come here to ask for help when im at a learning curve. This should be fun guys! Wish me luck.
Reactions: 2
you dont need to post a video
if you are following the choke sequence (sounds like you are) the bike is just hard to start because one of the carbs is screwed up
Reactions: 3
OK, I know all the lead up to cleaning a carb, but Ive never had to do one myself
Seafoam has kept my carbs clean so far (which is good, Ursa has 4!)
there are several other people here who have done many carbs, and they are always happy to help
there are also several threads on carb cleaning and rebuilding for the 650
Reactions: 3
Thank you, I really appreciate the help.
Reactions: 1
You are in good hands with KCW, he's one of the experts on the 650.
Plus one on all the above, I would just like to recommend pulling the sparks plugs to see what they look like. If you are not sure how to read them, take a pic of each and post on this thread for us to see. They tell you if the bike is running too lean or too rich.
Reactions: 1
Recap: I opened up both carbs and cleaned the first one. The second carb got a screw snapped off. Not sure if this was how it was but once I put like a 6mm socket on it and began to loosen the bolt it came off like if it was there but barely.
92200
See less See more
how the carb looked before I took anything off on it. Question : would I have to re thread the tap?
92201
See less See more
2
Don't panic, should be an easy fix. That screw is brass with a hollow body.
92202
They get seized and break easily. Get some WD-40 and soak that area. With a fine thread screw extractor you should be able to carefully get it out and cause no damage to threads. You need to be slow and careful. Don't use a course thread extractor, you won't be able to get a good bite. Keep us informed on your progress.
92203
See less See more
Reactions: 1
Thank, you. Im waiting on my rebuild kit to come in the mail. While I wait ill be getting that screw out.
Reactions: 1
1 - 20 of 44 Posts
