1 - 16 of 16 Posts
Okay so I’m fairly certain my title says V Star 650 Classic. (Just registered it so I have to wait to get it back in the mail). When I check the vin on Autocheck it comes up as V Star 650 Custom/Classic/Silverado. So I went ahead and ordered the 7” headlight replacement. But when it got here it was TOO BIG. And I’m thinking, WHAT THE HELL! It says it fits V Star 650 Classic!
Did a quick google image search and saw my same headlight on a Custom. Then I started comparing pictures and fellas/ladies I definitely 100% own a Custom not a Classic. I’m not concerned about the title issue either it will be a simple correction or I’m just going to leave it.
What I am concerned about is that this thing has a 5 1/2” headlight which almost no one makes a good looking headlight replacement for! There are 7” headlights all over the place! Even 5 3/4” has a few good looking ones. But 5 1/2” literally has only the basic standard headlight design.
Here’s what I was going for
94733
So my question is, are there any similar aftermarket headlight options that are 5 1/2”?
Or are there good sources for Classic headlight housings that aren’t crazy expensive, that I’ll 3D print a bracket for to mount to the Custom’s mounting locations?
Or maybe you guys have other ideas that would get the same look?
Unfortunately without a lot of modifying and expense you are limited to the smaller headlight. Yes, there are more 7 inch since they also fit many cars with the main one being Jeeps. There are several halo headlights that fit your bike, here's a sample.
94734
Reactions: Cameron23
So I saw these and they say 5.75”. I imagine they’ll probably fit but I wonder about how to mount them in the ring. I doubt they’ll have the same mounting holes that the current light has on it.
My bad, I just google 650 Custom LED and those came up. Hopefully someone that has done LED on same bike will chime in.
I think a 5.75” might work size wise. I’d just need to experiment with ways to mount it.
Luckily with a 3D printer bracket possibilities are endless.
on your title, the only thing that matters is the VIN number
the model names are made up words that mean nothing
2001 VStar 650 Classic
I own a 650 Classic, but it came with a custom headlight housing. I wanted to replace the headlight with a 7" LED similar to the one you show in your original post, but that was not possible, the housing on the bike was 6 1/4". I ended up buying the original one on EBay. It must have been my lucky day, I found it complete for $45 shipped with the mounting bracket and bolts. Although I didn't need the bracket and the bolts. Now I have a light housing sitting in the garage collecting dust.
EBay is your best friend, be patient.
94751
94752
Good to know!
I have a feeling it’s going to be a custom bracket to mount a Classic headlight housing to a Custom. Just looking at the pic it looks totally different.
The bracket is simple to change out it is only 2 bolts through the lower triple tree, below I have pictures from partzilla showing the 2 bracket setups, I would buy the housing off of ebay .The top one is the classic , the bottom is the custom.
94754
94755
It’s true about the VIN numbers, as long as the VIN matches your license plate, you’re good.
Discussion Starter #13
FYI, you have a custom. Those are custom forks. Classics have big beefy fork covers on the top half. See robby's pic.
Right that’s what I was trying to say in the original post. That I thought I had a Classic but in fact I have a Custom.
1 - 16 of 16 Posts
