Hello everyone,
I've just made the worthy investment of switching to LEDs. I've ordered the respective 3 pin flasher relay for LEDs.
My question is, how do I properly wire the unit such that I maintain the self-cancelling feature?
Thanks.
Here's a thread with the info:
So, just to make sure, I just have to connect the brown and brown/white? The black (ground) wire gets left with the original relay, and the ground (-) on the new 3-pin gets left open?
2008 Vstar1300
There is also a relay mod you can do to the factory relay..
Reactions: ghostlyone
I just tried the 2 pin to see if it worked... didn't seem like that particular one worked. Even with its highest resistance setting it didn't work; it juuust started to blink in the rear (both at the same time mind you) and very faintly. Front signals still just go both constant on once the signals are engaged.
