New guy here. Have been reading the forums for a bit but decided it's time to jump in and hopefully get some advice.
I am attempting to bring my 99 V-Star 650 Classic back to life after a spill I had on it and let it sit for far, far too long. Like around 4 years too long.
Plan originally was to just sell it for parts or whatever and buy something else but that didn't happen. Now with gas prices, I am trying to get it running again.
So far I have replaced parts that were having issues and I'll list them below.
Exhaust - a set of used Cobra's from eBay
Rear brake shoes
Carburetor joints and new bands
Spark plugs
Oil filter w/oil change
Fuel filter
Battery
Various parts that were destroyed when I had the accident.
It was originally leaking fuel from around the rear cylinder. Learned if gas is not going through to the cylinder it will overflow and leak out the back, so I had to pull the carburetor out and clean it as best I could. Unfortunately, I couldn't get to the jets because the screws were rounded off by the previous owner. One of the diaphragm's was stuck, which seems to have been causing the gas to overflow and leak so I used some carb cleaner and cleaned it and it now moves fine. After reinstalling, no more leaking gas.
Now when I start it, it fluctuates between blowing gray smoke which changes to white and then disappears and not blowing any smoke out of the top exhaust. The bottom exhaust originally was as well, before I cleaned the carb, but it is not anymore. There is also white smoke coming out from around the top pipe and its connection with the rear cylinder. Used exhaust, so figure it's just burning stuff off. It also won't stay running. It is not leaking any fluids anymore, it is not running rough, and I can keep it running by holding the throttle open, it just won't stay that way once I let go of the throttle. I was able to get it to start without choke and without throttle a couple times after it died but then it just dies again around 30 seconds later.
There was about 1/2 - 3/4 a gallon of gas in it that I did not stabilize. I know, that's bad. I was told by a number of people to just put fresh gas in with the old gas if I didn't want to drain it and it should dilute it enough to run. It did seem to do the trick as it does produce ignition. I was also told it wouldn't hurt to put Stabil in it now and it might help. I have not done this yet.
The spark plugs do have some black around the electrodes but I figure that is pretty normal since they are sitting next to a tiny explosion but I could be wrong.
I have some mechanical skill and do most of the work on my cars so not afraid to pull the whole thing apart if necessary, just really hoping I don't have to.
Any advice, direction or pointers will be greatly appreciated.
Rear brake shoes
Spark plugs
Fuel filter
Battery
