1 - 20 of 25 Posts
Hi All,
Just installed a Kuryakyn 4612 conversion kit so my rear turn signals turn in to running and extra brake lights. After a minor mishap where I broke the retainer clips off the brown and blue wires I was ready to swap the rear lens covers and bulbs but the rear bulbs are Amber and I need either clear or red bulbs. I tried AutoZone but they did not have what I needed. The catalog did not list a number for the bulbs. Would anybody have the bulb number? IE 1157 etc? Any help would be appreciated I have a 2009 V Star 950 Touring. The pins on the light bulb body are slightly offset down as opposed to a 1157 bulb where the pins are straight across.
Thank You!
They are an 1156
Edit: They could be a 7507 like my 1300, but an 1156 is basically the same bulb.
Mfwright is correct. I added the same kit to my 09 950 tourer and traded out the halogen bulbs for LED red ones. Huge difference in visibility and it looks cool when activated, because the rear lights flash three times.
I personally just added a red led bulb on mine for tail/brake.
Also for reference the front turn signals will be 1157 also. I swapped mine out with switchback 1157 led, white/amber. If you have passing lights, it might have been converted to a 1156 though, I don't have passing lights on mine.
One the dirt bike instrument guage, it has blue/green/red, and instead of getting several different colors (seems if I pick a brand I can get blue or green but not both). I just tested with a white led, and it worked for all of them, so just ordered white all around.
OK, I put this kit on my '15 950T when I bought it. Currently using the 1156 bulbs but would like LED's. All the LED's I can find say nothing about changing brightness with voltage. The 1156 bulbs in there now are half bright normally, but get full bright when brakes or turn signal is used. Do your LED's work that way or they just on / off?
Thanks in advance.
I mistyped, 1156 are single, and 1157 are dual
That is how 1157's work.
Bulbs don't change based on voltage, as the voltage should always be 12v.
The 1157 have two inputs, one input is for 5w brightness, and the other input is for 21w brightness. Depending on what wire has power depends on how bright it is (like your headlight bulb). Except normally on these the low power one stays on all the time unlike your headlight.
The 5w input is used for your running lights, or tail light. the 21w input is used for turn signals and brake light.
Depending on the LED you use, if it's single color, it will work the same exact way as above.
If your using a switchback led, that means it will change color depending on the input, and normally (I haven't seen any) not change brightness, both inputs will be full brightness. So you wouldn't use a switchback led on your brake light.
But using a switchback led on a turnsignal light means the normal low power amber running lights you have on the front will now be full brightness white, and when you use your turn signals they will change to full bright blinking yellow.
https://www.amazon.com/SiriusLED-Extremely-Chipset-Projector-Signals/dp/B0105LW4CK
Ones like this one will either adjust the led voltage, or only light some of the leds on low, and use full voltage or power all the leds on high brightness. LED's normally run in the 1-3volts range, so they always have to convert it in the bulb from 12v.
https://www.amazon.com/SiriusLED-Switchback-3030-Chipset-Projector/dp/B01ES4AUDA/ref=sr_1_6?keywords=led+1157+amber+switchback&qid=1554686642&s=gateway&sr=8-6
These will run full brightnes on both low and high, except low is white, and high is amber (turn signals).
Be careful when changing out your turn signals with LED though. You need to make adjustments or replace your flasher unit with an electronic flasher, and maybe add diodes to your turn signal indicator.
Some LED's only power one way, and you have to flip them if they don't light (1156/1157 you cant flip, but like the car reverse/turn light ones, T10's) you will probably be fine.
If your LED is nicer and works both ways (they have diodes in it to idiot proof it), then your your likely get 4way flash on all your turn lights.
Sorry, I misunderstood, that brake controller gives tail light to the turn signals using lower voltage.
Exactly. So I guess I'm looking for a red led replacement for Kuryakyn 4620. Sent them (Kuryakyn) a message last night asking about it but have NOT received a reply yet.
Best bet is to look for a BAW15s or PR21W if you want old style incandescent bulbs, or 7507 for LED.
Here's a link for the LED
Redbird I changed the lens covers to red also. Custom Dynamics carries and were great to deal with.
The LED bulbs and red lenses gave it a very deep red look enhancing more visibility. I also added an LED license plate frame that I wired into the Kuryayken unit giving me even more visibility.
:surprise:That's expensive!!! $17.99 per bulb?! :|
Hmmm. Not sure where that came from. I see $6.95 for 1 and a 2-pack for $13.90 on that page. Not cheap, but considering its Kuryakyn its less than I expected. Have to add shipping, but that should be only about $5.
Attached a screenshot from the site. For some reason on mine it's not $6 or $7.
Discussion Starter #16
2lane, The more I look for this information the more confused I get. I believe the lamps currently on my bike are 1156 Ambers. They also have the pins on the case of the bulb at about 150 degrees instead of what I have been seeing when I go to an auto supply store and I see the 1156 clear's the pins are 180 degrees or more in line with one another. When I looked at the Kuryakyn site I saw the bulbs you referenced in your post but when I did the fitment for my 09 950 the only ones they had were clear or amber...No Reds...I did an online chat with Kuryakyn and the person there said to stick with the 1156 bulb and it should be okay. I am wondering if I will need to change out the socket so I can get the bulbs with the pins directly across from one another..My bro works for NAPA and he thinks I am losing it....He may be right... Any how appreciate the information very much!
Redbird58, You’re looking for a 7507. It’s basically the same as the 1156 but pins are slightly differently spaced.
Just click where it says red
They’re good bulbs, not a horrible price. I used the same bulbs in amber on my 1300.
2lane, no worries. I actually checked 3 times and cleared caché on the price before I posted because it didn’t look right to me.
Mfwright79,
Did you use those LED's with the Kury RTB unit or just as replacements in the stock system? (The Kury RTB system needs LED's that are capable of 2 levels of brightness even though there is only the single contact on the base.)
Thanks for understanding and all the info!!
I don't have any RTB system on the bike yet, so I'm not 100% sure on that. I'd go out and pull the bulbs and test with jumper wires, but I currently don't have any running lights due to a wiring problem that's affected running lights, and blew my headlight. I wish I had more info to help with, but til I fix the wiring issue, I can't test it. I do know that the 7507 has the pin layout that Redbird was looking for. Also, I've modified 1156's to fit the 7507. I can't seem to find info as to whether or not the 7507 can do dual brightness. I'd say changing to an 1157 socket may be the easiest, if not the cheapest bet, without being able to test my 7507's with some wire and alligator clips.
I have the Kuryakyn triple play on my 950T and the bulbs that came with the kit were dull and a poor color match for the center brake light.
I got a couple red led (1156 I believe) from auto parts store.
Filed one pin down slightly until bulb went in and it stays in place. Beautiful color match and brightness to match tail light.
2 years and 10k kilometers later no problems.
1 - 20 of 25 Posts
