I’ve researched all I can and haven’t gotten a solid answer. Can you put a Venture seat on an Eluder and then get the tall backrest?
I have a Vstar 1300 that I highly modified. I wanted to use parts off of the Vstar 950 and and Stryker 1300 and found that a lot of times you can study the parts blowup drawings and help determine if they may fit. Typically the parts guys aren't going to know what parts interchange from different bikes. I found many parts that I could bolt on from the Vstar 950 and the Stryker 1300 with my Vstar 1300. Typically manufacturers will try to reuse designs so the don't have to reinvent every part for every bike.I’ve researched all I can and haven’t gotten a solid answer. Can you put a Venture seat on an Eluder and then get the tall backrest?
