Hi , I can’t for the life of me figure out how to remove the left side cover to remove the ecm to send it to Ivan , I’ve removed the security star and the cover is loose , I can’t really see behind it to see if it’s just a grommet that’s holding it? If that’s the case then which direction do I pull? I’ve tried the search function.
the covers on these bikes are all the same
it is a grommet, and you either push it towards the front wheel, or pull it towards you... I can never remember which ones are which on the covers on both of my bikes
you should be able to pry it out far enough with the one screw removed to see which way it goes, you would have to go really nuts on it to break anything
