I drilled out the Welch plugs.i used a screw to pull the plugs out. The drill bits never touched the screws..I turned in the screws to get a base line,as I turned the screws back,it became harder to back them up,I ended up ripping the slot right off the back carb screw.
Now what do I do? Do I buy a new carb..
Damn 15 minute job turns into a Night mare.
Sent from my SM-G955U using Tapatalk
Welcome from Houston, Texas. Must have been some corrosion in threads. I would soak with penetration oil, let sit, drink a coffee or two, then try to get some small needle nose pliers in there to grab screw turning it in and out to loosen corrosion. Here's a few interesting threads to check out when you get a chance.
https://www.starbikeforums.com/forums/6-new-member-introductions/116742-location-garage.html
https://www.starbikeforums.com/forums/49-v-star/5655-yammy-ya-got.html?highlight=Yammy
https://www.starbikeforums.com/forums/36-lounge/110258-where-you.html
https://www.starbikeforums.com/forums/11-general-bike-talk/25113-how-experienced-you.html
https://www.starbikeforums.com/forums/36-lounge/113714-how-mature-you.html
Ride often and safe.
Welcome to the forum from East Tennessee.
You’ll get a lot more feedback on your issues by posting your questions in the Vstar section. The introduction page is a formality in joining the forum so we can get to know you better and help you along with your issues.
This is a great forum with an extremely helpful membership and you won’t get the attitude that it’s been asked before.
Please keep us updated on your progress and share a pic or two of your ride when you can, ride safely!
