HELPPPP Hello I'm new here an hopefully found the right place for an answere. I have a 07 vstar 650 classic. I put 6 inch risers on it today an had to Un hook all cables to reroute wires. Well hooked everything back up an turned key on an didn't have my headlight come on. No idea what the prob is. Any help would be appreciated.
Welcome from Southern MD!!! Do you have high beam? Could just be a coincidence that the low beam blew..
No I tried switching from low to high an nothing. I can't start the bike right now because I'm waiting on crank case gasket to come in. Should be here in morning. I have no idea an I'm no good at rlecyrical.
Check the fuses then, not sure where they are on the 650.. On the 1100 they're behind the side cover where your tools are.. GL!
You could also check for cable breaks and/or corrosion near the connectors you removed and reseated. Is the light the only thing not working?
BTW, welcome to the forums from the Netherlands, and safe riding!
Kind regards, Wim
