yes
Check underneath the carburetor. It's usually a screw with a spring around it with a black plastic nut on the end of it. turn left and right for idle adjustment
The 950 is fuel injected so no issues dealing with a carb. As in the posting above from bevo, I'd try disconnecting the battery to reset the ECU and see if that helps. Good luck and let us know how it goes.
