Hello, first post here but am hoping for some help. I have a 2005 VStar 650 custom. Last week I noticed my bike was leaking oil from the final drive. Decided to repair this myself, it turns out one of the bearings exploded and got chewed up in the gears taking a few orings with it, hence the leak. The bearing should be easy enough to replace but the problem is getting one of the retainer bearings out. This looks from the diagram like it was pressed into the housing. My question is does anyone know of a tool out there I can use to remove this bearing. I know there are several bearing removal tools out there but didn't know if there was one I could get either specifically for that bearing or a set for Yamaha's. Any help would be appreciated. Thank you.
{link to schematic http://www.bikebandit.com/houseofmotorcycles/showschematic/m10309sch521465
Bearing that exploded and needs replacing #9
Bearing that I need to remove #10}
