1 - 2 of 2 Posts
Only happens when pulling into an area where I am slowing down. (eg. Pulling into a driveway, or at a gas station). Seems like the bike just had the kill switch hit, but that's not the case. If I crank it right after it will start right back up again. Could there be something loose in the throttle that could be hitting the kill switch wires, or if I am pushing forward on the throttle control too much could it close the carb enough that it just dies out from low idle?
Check that the idle RPM's are set correctly......
1 - 2 of 2 Posts
