5241 - 5246 of 5246 Posts
2000 Yamaha XVS1100a Classic
I got the 650 left side hand controls a couple of days ago and tried to install it today. The plugs are not the same at all so gave that up and stuck one of the side cover Yamaha badges on the top of the triple tree instead. At least something got done... :cool:
105353
I put a couple of miles on the tires.
However as I was doing an inspection of the bike. I noticed on of my driving light was out. (Add on lights. Not OEM to the bike.) Looks like I might as well order two. If one goes. It's probably not long before the other one goes.
Ride smart. Ride often.
Got back to fiddling with the 650 switches, pulled the innards from the 1100 switch casing and installed them into the 650 casing. Of course the 650 one didn't have the brights flasher switch hole so out with the dremmel and cut a hole. Not perfect but it works, and I'll probably be the only one who ever notices that the hole isn't 100% straight. Then of course I discovered that the spring on the hooter button only goes one way and that way was not the way I replaced it... and then had headlight problems that turned out to be the bright/dim switch that had come slightly apart and wasn't making contact on the points... all in all I had that sucker open and closed about four times, but I learned a bunch that I wouldn't have learned any other way. I'm a happy little motorcyclist today! 😊
105423
105424
105425
Reactions: lesblank
My 650 has the high beam flasher button, but it does nothing. Just as with my son's MT-07, that button does nothing, either. Not sure if they are not connected from the factory, or if something is malfunctioning. Not important enough for me to check on.
The flasher button would have to be something for EU, here in the United States they don't even have that button. We have High and low beam, turn signals and horn on the left side. On the right we have Kill switch and starter button.
