What did you do to your bike today?
553061 Views 6353 Replies 508 Participants Last post by  Scuddy
104317
I washed and polished her up.
Then took her on nice little 135 mile putt.
Now I'm gonna build a fire outside and sit
and drink some wine. See ya'll,
Ride safe!
See less See more
Reactions: 5
6281 - 6300 of 6354 Posts
Yesterday, I sanded down my frame and wheels. I am getting them ready to paint. Today I will complete the rear wheel and move on to all the chrome one the motor.
Reactions: 1
I got a slight twitch in my handle bars. Part of the tire was worn on the other side I ride the 650 on my commute and use the Strat for shopping .
  • Helpful
Reactions: 1
I finished the Ammo Can Saddlebags. I decided on satin black paint. As I mentioned before, they use the same mounts as the OEM saddlebags. Here's a few more pics. I am totally happy with them, so far.
as both a WWII buff and a Mad Max fan, you are tempting me terribly. especially as i have a welder and they're only like $35. but i have to know... do you feel the weight of them? the site i checked said they're 14lbs each, and i feel like that would be noticeable.
Reactions: 1
I probably carry 14 lbs worth of stuff in a saddlebag, it you can detect a difference of 30 lbs on a bike balanced between the 2 sides I'm impressed.
Reactions: 1
i'm not sure how you wouldn't, but that might just be me...
i was just asking if it made a substantial difference.
I weigh in at about 240-ish and have not really felt a big difference, but when I got the package delivered I was surprised at how much they weigh.
Keep in mind that the 40mm cans are NOT hinged on one end like the smaller cans, so you have to bolt one side closed to make them hinged, and also you have to add hardware to make them lockable, but I will be happy to show you how to do both. It's easy.
  • Helpful
Reactions: 1
Yeah, if I get em I was planning on welding the one side to hinge it, welding spacers and probably braces for mounting, and probably welding little tabs inside for barrel locks like normal bags. Can you tell I don't use my welder enough?
Reactions: 1
I had painted the engine a week ago. Painted the engine cooling fins a few days ago. Got the repainted and polished floorboards and controls back on today. Need to check the rear caliper as I think it’s dragging. Coming together.
Tire Wheel Fuel tank Motor vehicle Automotive fuel system
See less See more
  • Love
Reactions: 5
That's looking really nice.
Reactions: 1
Thanks! A real close up look you can see it's not perfect. But for a 20 year old bike it's coming together pretty nice. I need to get it finished as the weather is finally showing some signs that riding season is nearly upon us. (y)
Reactions: 1
That's cleaning up real good! Nice work.
Reactions: 3
3
Got off my butt and decided to do a cooling system flush and refill, it’s been 3 1/2 years since I did it last. Took some short cuts, but did a thorough job flushing it twice with distilled water, this time around I removed the lower radiator hose to get that last little bit out of the low point.
Hood Automotive lighting Automotive tire Motor vehicle Automotive design
Automotive lighting Automotive tire Hood Motor vehicle Automotive design
See less See more
Reactions: 4
Ahh, finally a day above 30 degrees and no rain. Changed the gas, changed the air in my tires and changed my attitude. 60 miles of smiles. Wind therapy works!
  • Haha
Reactions: 5
6
Continuing On With The Maintenance: Changed oil & filter with my usual Mobil 1 10w40 motorcycle oil & Wix oil filter. Last oil change was done a little over a year ago with a run of 5,100 miles. Cleaned external crankcase breather filter, Replaced worn rear brake pads and re-greased caliper slide pins. I thought I would add a pic of my oil filler cap, I wire it for piece of mind, as it’s just to easy for someone to access, like
Tire Fuel tank Wheel Automotive lighting Automotive tire
Motor vehicle Automotive lighting Automotive tire Hood Automotive design
Automotive tire Motor vehicle Automotive design Automotive lighting Hood
Tire Wheel Automotive parking light Window Automotive lighting
Tire Wheel Automotive tire Hood Automotive design
when out of town and doing an overnight-er @ the Bates Motel 😧. Also, Hoping to get one more long distance trip out of this Michelin Commander 2 rear tire, which currently has around 16k miles on it. Next on the agenda is to give the bike a good cleaning
Shoe Textile Wood Sneakers Font
See less See more
Reactions: 2
Nice use of the chain side plate.
Be careful while in the shower at that motel.
  • Haha
Reactions: 2
Today Stella ('08 Road Star) got a new rear Michelin Commander II tire. By the tread depth I still think the one I took off (another Commander II) had a few thousand left in it. But I'm planning a trip next month to Texas to attend the 2023 Texas meet and greet and ride around the countryside with @lesblank and @AlanRides. I'm guessing I'll put on 3K on that trip so I didn't feel pushing to get all the goody out of the old tire was wise. I'll hang on to the old tire should I or someone I know need it for emergency purposes.
On another site I participate in, the topic of changing one's own tires came up. I grew up in small town Iowa and worked in a service station as a teen, and then a part time second job in my 20's so I am well versed in working on tires. I've done much of my own repair on car/truck/implement tires over the years as well since we have the tools at my dad's shop. But I hadn't had a need for motorcycle tires until recently. So here is a pic of my new tire prior to mounting. On the floor I have a large slide hammer type device to break the bead. Not as easy as a lever activated one but it just happen to come with a bunch of other tools I'd picked up at auction. So you use what you have. Then the spoons. One I believe is from an old Model T type leaf spring. The rubber ended mallet is one we had back when the folks owned the service station. This tire was easier to do since it was on a cast wheel. The '03 Road Star (Black Betty) I picked up off this forum has spokes so they have tubes and are tricky to mount and dismount without damage. A pinched tube can ruin your day. :cry:
After the tire was installed I put on a set of Freedom Performance true duals. I've lusted after them for many years. I came across a deal (steal really) that I couldn't pass up. Unfortunately it was late in the day and I forgot to take pics of that. I have a few more things to button up on it before my journey. This will be by far the longest trip I've taken on the bike and I'm looking forward to it. It's been a long winter and I'm in need of wind therapy. :LOL:
Wheel Tire Automotive tire Tread Road surface
See less See more
Reactions: 3
Got my new (to me) Corbin seat installed. Will take some better photos in the sun light
Vehicle Automotive lighting Automotive tire Hood Tire
See less See more
Reactions: 5
Got my new (to me) Corbin seat installed....
Looks nice - I bet it almost cost as much as my whole bike. :D
  • Haha
Reactions: 1
Yeah, I understand they come with a pretty big price tag off the shelf. I have been doing my mods pretty price conscious. Managed to pick up the seat for $200 Canadian, pretty reasonable I think, and I am sure happy with it. Great riding position, firm and comfortable, will be great for some longer trips.
I have been able to find everything I need except a dang exhaust. And when I do see them for sale people want an arm and a leg
2
Did my first brake caliper rebuild.
Eyewear Sunglasses Goggles Automotive design Aluminum can
Motor vehicle Automotive lighting Automotive tire Automotive design Nickel
It actually wasn’t as hard as I assumed. This is from the '03 Road Star I got off this forum. The rear caliper was stuck and causing the brake to not release. I wouldn't be surprise if this wasn't 20 year old brake fluid. I've changed many calipers on cars over the years. But with those I'd just go to my local auto parts store and get a rebuilt caliper and install it and then return the core. Not quite the same on the bike (or at least I didn't know where to buy a rebuilt). Looking at online parts places a new caliper was way north of $500.
I did a quick search of how to rebuild a caliper (I felt comfortable that I knew exactly how they worked and what was inside) and seemed straight forward. Well it would have been just as the video had it come apart easily. Since the pistons were pretty stuck I buggered them up trying to pull them out with pliers. So instead of just a seal kit I had to buy one with new pistons as well.
On another forum I'm also active on I asked suggestions. Most replied to use an air compressor to push the pistons out. But getting a good seal to keep the pressure and also not having them become projectiles wasn't going to be an easy task. I had someone suggest a grease gun (which I have several for different purposes). Come to find out, the bleeder valve is just like a grease zerk in size and it will clamp on (I had to unscrew the gun tip apart to get it to release however). That gave me a good slow controlled push of the pistons. It also required a few C-clamps to control them so one didn't push out and loose all leverage. Unfortunately I wasn't thinking and didn't take any pictures.
Cleaning up the gun grease was not fun but wasn't hard. I soaked it in a bath of Simple Green which I like to clean parts, then a little brake cleaner and compressed air to get it ready for seals. Before I did seals there was internal corrosion so I ran a wheel cylinder hone in it and also used a pick tool to clean the seal grooves.
I'm happy with how it all went back together. I considered painting it first but it wasn't scratched bad and it's going to be on the rear hidden under a bag.
Anyway, I learned a few new tricks along the way and thought I'd share for those who've never done this.
See less See more
  • Helpful
Reactions: 5
