1 - 11 of 11 Posts
I want to be able to trailer our two bikes when needed. I've looked at 6x10 utility trailers and even the rail type trailers specifically for motorcycles but don't feel comfortable with them. They look flimsy and cheap. What kind of trailers are you using to haul your rides with? Just trying to get some ideas.
I just had my 1st Motorcycle trailering experience this week. Picked up my 2007 V-Starr 1100. It was about 350 kms from my place. I had bought a single rail Stinger trailer for this job and for future times if needed. It was rock solid and easy to load / unload. Not flimsy or cheap. There is a double Rail version for two bikes available also. See attached pictures.
Pro's:
Not expensive compared to others.
Easy one person Load / Unload.
Well made quality product.
The design does not require that you compress the suspension to secure it.
Folds to the size of a large lawnmower for easy storage.
Cons:
Does not seem to like to go faster than 100 kph (60 Mph).
There is a bit of vibration after that.
It's an open trailer so your bike is exposed.
one thing to be aware of with any trailer
if you buy a used one, jack up each tire off the ground and give the wheel a spin: if the bearings make ANY noise at all other than an even continuous smooth sound, if it makes uneven sounds as its turning, then it needs new wheel bearings.
That is not grounds to pass up on a good deal on a used trailer, but replace the bearings before you tow it more than 5 miles, esp at highway speeds.
The bearings are easy to replace before they melt and fuse themselves to the axle, and you end up in a Perkins parking lot at the interstate exit at 7PM on a friday, 256.4 miles from home, with a sailboat on the trailer.
KCW That sounded like a life experience there...So what did you order from Perkins for dinner that night? Breath deep, happy thoughts...it will be okay! ;)
Drank lots of coffee and ate something at Perkins. The manager was very nice about us having a roadside workshop going on in their parking lot.
It was my nephews new (used) 18 foot Hobie Cat, pulling it with my Saturn Vue. Purchased in Connecticut, we made it to Springfield MA till the bearing on one side blew out, and was flopping on the axle (did not come off all the way).
Was able to find an Advance Auto store not far away that was just about to close. Nice lady found us a wheel bearing the right size, but the inner race of the old one had welded itself to the axle. I think the race partly melted as the wheel was spinning at 70mph, and when we stopped for a light it fused to the axle.
Lots of chisling and filing and hacksawing got most of the race off, and we were able to get the new bearing on just far enough for the cotter pin to catch the hole, by putting the castle nut on backwards.
we stopped at every rest area on the 256.4 mile ride the rest of the way home to check the wheel.
We did jack up the wheels before he bought the boat and trailer, the one wheel was making just a little bit of noise when we spun it.
And thats the thing: if the wheel is making any noise with just the 10 pound weight of the wheel on it, its going to be grinding with the full load of the trailer on it. Trailer bearings are just snug fit on the axle. If the bearing does not want to spin on its balls or rollers, the inner race will spin metal to metal on the axle.
That sounds like an ordeal a couple of friends went through recently. One was going to buy a 55 Chev in FLA. So they planned a road trip from OH driving straight thru..pick up the car..sleep for a little then head back. Well most great plans have some weak spots in them...In this case it turned out to be the trailer..New tires.. but 2 of them decided they did not want to be clothed and shed their treads on the highway...luckily they were pulling a 2 axle trailer...Good ol Wally World they picked up 2 new tires and thought they would be on their way again...Jacking up the trailer they found some of the floor boards were hit pretty good when the tires shredded and exposed some weak floor boards....Turns out the car was junk and they did not get it...The bad thing was as part of the deal they had a Harley Bagger on the trailer that was part of the deal for the car...when they jacked it up the bike broke thru the weak boards and got a little damage...Had they had a 2 wheel trailer they would have probably lost the bike and been in a bad way if they could not have stopped...I think they learned their lesson...
Well fellas I purchased a Kaufman 5 x 12 , single axle trailer to trailer my Motorcycle and UTV when needed. I have been very satisfied the past six years. Just to let you know my Vstar 950 T loads fine and clearance is fine. I had a MC chuck installed which keeps my bike centered along with tie downs.
Hope this is helpful!
Ride safe and enjoy!~YammyV
We have a home built 5 x 10 utility trailer that I have been using the last couple years to trailer our 950 to Johnstown, PA bike rally. I have added a Harbor Freight wheel chock to put the front wheel in. Since our oldest daughter picked up a Bolt, I would like to get an enclosed trailer to put both bikes in but fit a third bike occasionally. Just haven't decided I want to spend the money.
1 - 11 of 11 Posts
