I am looking to get a back rest and I have two square inserts under the labels where they would go. The seats I am seeing have a rectangle mount. Mine is square.
There's no embossing or manufacturers decal on the underside? Is the base metal or plastic?
It is bolted down. I will need to unbolt it and check.
Where the back rests would go it has a label that flips up the expose the mounting point. It is just the same pattern that is sewn into the seat
It should take less than a couple of minutes to unbolt both the passenger and driver's sections and check. While you have the seat off you can clean and inspect that hidden section of the bike to ensure everything is in order. That pattern on the seat just looks like the V-Star logo.
