Does anyone know what is causing this whirring sound, when i let of the throttle...[coast], and when i'm 2 up it does it around 50 to 55 mph if throttling or not.
at first I thought it was the tires, like when they start to sing in a curve...but it happens on the straight also.
thanks for any help
as for the ride: now that I have the mustang seats and Bucks lowers for wind deflection, it is a joy to ride, with no stress at high speeds.
Vince
it seems no one is giving you an answer yet..
I had a roadstar and they do the same, usually the drive belt needs adjusting to fix check how tight it is. see if that helps.
Paul
I am hoping to get a stratoliner this spring and was reading about likes and dislikes. seems most are happy and just little problems making it theirs should cure.
Discussion Starter · #3 ·
whirring noise
thanks bow hunter....it turned out to be much worse than that.
it was the main drive bearing.... about 2100.00 to fix.....thank God yamaha came to the party for most of it....i still had to put out 500.00 for the diagnosis...i went to cycle world [ cherry hill]to ask for the diff. since i bought it there and they should have known there was a problem when i bought it, but they told me to pound salt!
yamaha is a great product and they stand by their stuff. i now have a warranty till 2011.
thanks again
vince
thanks again
vince
wow how did you get yamaha involved? thru a dealer? hard to believe they would pick it up after so long.
Discussion Starter · #5 ·
yes, i took it to flemington yamaha...they looked it up and apparently the original owner had an extended warranty....which should have been passed on to me...but cycle world never told me, and sold me another outside extended warranty....700.00
zurich would not uphold the damage as they said it was pre existing...so i went to cycle world and got my money back for the zurich warranty....6 mos later, i finally got the check....the whole thing was a mess... cycle world was NOT customer friendly.
so now i know i have an extended warranty till 2011.
wanna buy a beautiful silver Stratoliner that runs great now?
Vince
well I'm glad it is all worked out and a shame on that cycle world for not taking care of things to start with. Guess I know where the recommendations will be.
Sometimes that belt gets over tight which is hard to do and it will strain the bearing. Good luck and ride safe.
Paul
Extended Warranty
Wow, that was one of the 1st things I checked before I bought my used Stratoliner S. Of course I was already familiar with Yamaha's extended warranty because I had it on my 2001 Roadstar which I bought new in 2000.
2006 Stratoliner S -- $12,200.00
4-year extended warranty out to 2011
Mustang driver and passenger seat combo (also original seats)
Yamaha Speedstar Exhaust (also original exhaust)
Passing Lamps
Dynamo Power Commander II
Billet Passenger Floor Boards
Rear Luggage Rack
Saddle Bag Guards with Trim Rails
Big Bar Engine Guard
Not bad for a $17,000.00 motorcyle (before you add more than $4,000.00 for extras) less than 9 months old.
