Can someone confirm if a stock exhaust from an '04 1100 Classic will fit an '01 1100 Classic?
Thanks a lot!
When I was looking to buy an exhaust system all the listings showed fitment from '99 and up for the same parts. That being said, OEM should be the same.
Yes it will.
The only difference in exhaust is that the 06-up use a different rear mounting bracket. So you'd just need a bracket if it was newer....other than that...they will all work.
