Now I'm curious to know if by using those LED bulbs, I'd blind the oncoming drivers. Maybe leaving the switch in place would be a good idea - or just have them on when I have high beam on. Puzzling this out as I decide what I want. Fun nonetheless. Thanks for all the help guys!
This doesn't apply to the passing lights. One of the nice things about the direct replacement LED bulbs is (in most cases) that they maintain the same focal length as the original bulb. That keeps the same aiming point in the reflector so the angle should be the same as original. I haven't made enough trips at night on the Strat, just yet, but so far no one has complained (flashed their lights at me).
The passing lights. They are supposed to be aimed so they point slightly to the side and down to fill in the "light gap" underneath the head light. I'm thinking, that if you haven't changed the aim point of the passing light housing, you should be OK. If it were me, I'd keep the switch, if for nothing else, to stay legal. They are supposed to turn off with the high beam on. I don't know, does VT have a vehicle inspection; I know RI does. If you can't shut them off, will it pass inspection?
Last I knew, VT didn't have a whole lot of people in it (population around 400K). As such, fairly rural, like where I'm at now. I'd like to have as much light as possible when combating the critters along the roadside. So I would recommend (which is what I've done) is to use the most lumens I can get my hands on, which will fit.
