1 - 9 of 9 Posts
Planning on installing the Yamaha light bar & passing lamps.
Like some feed back wheather I should wire them into the high beam wiring or keep them on a direct circuit.
Like to have some feed back from my fellow riders.
Thank you for that info. I'm not sure what the laws are here in Florida regarding passing lamps. With all the old farts down here who cannot see, I want to be as visible as possible.
Thanks again for your feed back.
Happy Trails and Ride Safe.
Detroitoutcast.
Detroitoutcast.
they're supposed to be wired to the low beam but i wired mine to the high beam so they're not on all the time which puts a strain on electrical system. i was thinking about moving the on/off switch to where i can reach it while riding and wiring to correct low beam position. i'll never understand why they put the switch on the passing lamp bucket where it dangerous to reach while riding. if you run the passing lamps in city traffic when the carb heaters are on the stator doesn't have the power to cover the load. passing lamps are for others to see you not for you seeing the road better
I wired mine into the little toggle switch on the left driving light. That way I can switch it on or off with the high beam when and if I want. I really like them on with the high beams when riding at night.
you don't feel uneasy reaching over to switch it. on mine the windshield makes it very difficult to reach that switch. i pointed my right one more to curb and the left one down the middle. the right one really helps to spot critters that may jump into the roadway. i wish there was a vertical adjustment to get the beam a tad lower but mine only adjust horizontally.
Thank you for all the very good points. I agree with Pauli466, my main motive in installing them is for these old blind farts here in Florida can see me.
I also agree with the others that the location of the on/off switch on the passing lamp can be a danger. I've sent an e-mail to Kuryakyn to see if they can just sell me the handle bar switch instead of the whole harness with relay (their part no. 2202). I'll post their reply here for others to be informed. I may just go the route with the relay, hopefully lessening the load on the system.
I'm also installing the Kuryakyn Phase 7 LED headlamp for more lighting and hopefully lessen the load on the system.
Again, thank for all the helpful feed back and info.
Detroitoutcast
1 - 9 of 9 Posts
