- Reaction score
- 18
After gapping the plugs and adding seafoam to the tank, I rode around the block. The bike wasn't running right so I got out the can of ether and found a vacuum leak at the little hose (see red arrows for my replacement) at the top of the carb. I looked around for a week but didn't find any premade hoses that I wanted to buy, so I made my own. In the photo, the front carb in on top. See below:
I put everything back together but when I try to start the bike, it cranks but won't run. I pushed in the choke to the off position but still no joy. My first thought was no spark. However, every once in a while, it'll catch but at approx 200 rpm. If I give it some throttle, it dies. So I sprayed some ether into the air cleaner and it'll run that way. That told me I had spark. So I thought it's a fuel problem!
Fast forward to tonight and I pulled the tank so I can get serious about burning my eyebrow off. When I pour fuel down the throat, it'll run until dry. Ha! it's the fuel pump! When I go through turning the key and pressing the red button, the pump didn't run. I'm on to something!! I pulled the fuel hose to the carbs off and sprayed fuel all over when I turned the key on. So the pump works. If I drain the fuel bowls, the pump will run until they fill up again but the bike won't run unless I pour fuel down it's gullet.
Is it telling me the jets are fouled? If this were an edlebrock on a 350, I'd just get a hammer and fix it....
And then there's something else I don't understand. When I do get it running and twist the throttle, only the front carb looks like it's working. See below (again, the front carb is on top)
Is that normal or do I have larger issues?
I took these screen shots from a short video I made to explain what I'm seeing/hearing.
share.icloud.com
I appreciate any insight and suggestions you may have. I feel like I have all 3 components of noise and fun but I can't get them on the same page!
iCloud
Sign in to iCloud to access your photos, videos, documents, notes, contacts, and more. Use your Apple ID or create a new account to start using Apple services.
