1 - 1 of 1 Posts
Includes one roller bearing as well as the 5 nuts that bolt the pulley to the hub and the flatwashers that go on those same studs; bearing is tight and the oil seal is in good condition. Casting number on the part is 4WM-25366 . Part May fit other Yamaha cruisers. If desired I can machine aluminum off the surface of cush drive hub that your pulley bolts to to help with the problem of the front pulley being out of alignment from the factory with the rear pulley. On my Vstar 950 I machined off .075 inch which seemed to be nearly perfect. Your model may be different $175.00 with machining; $100.00 without. If interested e-mail me on the hotmail service at bigpig41 or PM me on this site
1 - 1 of 1 Posts
