· Registered
Reaction score
0
I cross-threaded the rear cylinder spark plug on my V-Star; the local cycle shop says they can put a Helicoil insert in to solve the problem; they said it is a "very routine" fix.
Has anyone had success or failure with such a repair? Please share your experiences.
Thanks.
· Registered
Reaction score
1
I'v done a couple. One on an old 60s Oldmobile with the 215 aluminum engine. Head bolt threads would strip on those simply by looking at them. The other was on a stripped thread on an outboard motor carb. In both cases the repair worked and I was able torque the bolt to spec with no problem.
The kits aren't cheap but if the installer is carefull it will work and is a whole lot cheaper than a new head.
· Registered
Reaction score
1
I've had it done on a VW head, done while I waited. No Problems sold it after 50K miles and no problems.
