Remove the two screws in the side of the head light bucket (one on each side). Then pull the bottom of the headlight housing (the chromed rim that goes around the lense) forward. Once the bottom is free you then keep pulling the whole housing out in a slight downward motion whilst rocking it a little to free the top piece.
Sorry - misunderstood your original post. I'm assuming that it's probably a case of a few choice swear words and some fighting with it to remove the clip...
It's been a while since I replaced mine but, I'm pretty sure I pried that clip out from either side of the outer ring. I don't remember needing anything more than a screwdriver.
How do you open it up? I have taken several tools to it and it doesn't budge. I there some trick to it? Like I said, it is probably simple but I have tried several things with screwdrivers and pliers.
Unfortunately I haven't had a chance to try it yet. Rain has been one issue. Another is I messed up the drl lights and blew one of my led strip circuits. So the only turn signals I would have is the headlight.
I like it. It has the typical led light issue of hard edges so very dark edges when turning. But much brighter than original. I have the JW Speaker adaptive light on my Victory. If it didn't cost also half the price of my Yamaha I would get one for it
It's a resistance issue due to LED lights requiring less voltage and you are experiencing a feed back issue. Normally an inline resister is needed to cure. Just google:
motorcycle led turn signal both side blinking at the same time
@SirPoonga I had a similar issue when I changed my turn signals to LED. Just the front was fine, but when I changed the rear as well it made all four flash at the same time. You can add load resistors like @lesblank is suggesting or there is a mod you can do to the wiring for your turn signal indicator bulb (it's backfeeding across this). Read this if you are interested in the mod:
I have done the diode. 5 years ago when I did it I understood why after looking at the schematic. This does not have that situation unless it is internal tot he headlight. Maybe that is the case. For now I unwired the headlight turn signals and just the running light.
Related Threads
Yamaha Starbike Forum
posts
383K
members
39K
Since
2008
